02-16-2021 07:39 AM - edited 01-05-2022 05:18 PM
02-16-2021 11:38 AM
@Rushan79 What plan do you have? What make is your phone?
02-16-2021 10:31 AM
i think it is sms texts. but i will check
02-16-2021 10:30 AM
Thanks I will give it a try
02-16-2021 08:08 AM
Can you send texts and make outgoing calls ?
See this thread.
02-16-2021 07:52 AM - edited 02-16-2021 07:52 AM
@Rushan79 wrote:Hello @PM,
I am not receiving texts and would like to know what I can do. I see that some other users have replaced new SIMS and that seems to have helped.
Please let me know,
Thanks,
@Rushan79 Is it MMS texts? If yes, you need to have data turned on to send or receive these ones (Pictures etc). They don't count towards any data limits.
02-16-2021 07:42 AM - edited 02-16-2021 07:42 AM
Please let me know,
Thanks,
Was a number ported? Do incoming calls work? If a port was requested, porting isn't finished. Look if the nofifications are enabled for your messaging app and if some messages are going into a text spam folder.
