Is this compatiable with Public mobile network.
I can make and recieve calls. I can't get 3G data to work
You can check your phone compatibility on this page: https://www.publicmobile.ca/en/bc/get-started
Just search Oukitel C17 and it will let you know if it's compatible or not.
Also, if you want to configure your data, here are the APN settings (search "access point names" in your settings)
APN: sp.mb.com
APN Type: default,mms,supl *
MMS/MMSC Proxy: 74.49.0.18
MMS/MMSC Port: 80
MCC: 302
MNC: 220
APN Protocol: IPv4
APN Roaming Protocol: IPv4
Leave all other fields blank/empty
@STom1688 wrote:Is this compatiable with Public mobile network.
@STom1688 if this https://www.devicespecifications.com/en/model/ccc751b8 is the correct spec sheet, then yes it's compatible. [EDIT: also, since it works for talk, it's defintely got compabitle 3G frequency(s).] As @aquintar noted, you may need to manually configure your APN settings.
On the home page, click GETTING STARTED. Scroll down and click on PHONE COMPATIBILITY and follow instructions to see if it works with PM.
@PAULRANG18 wrote:On the home page, click GETTING STARTED. Scroll down and click on PHONE COMPATIBILITY and follow instructions to see if it works with PM.
@PAULRANG18 always a good starting point, though this particular model is not yet on the list.
APN is grayed out. I only get the two Telus APN automatcially.
The phone version C17 is not listed
has anybody found a solution to this yet? I hace an oukitel c17 and cannot get the data to work. The APN settings are greyed out and cannot be modified
Get a freedom mobile SIM and insert it. The SIM allows you access to a lot more settings than other providers, including PM.
@jedimcse wrote:has anybody found a solution to this yet? I hace an oukitel c17 and cannot get the data to work. The APN settings are greyed out and cannot be modified
Try entering this into your phone dialer and press call: ##72786#
Then check if you can use data or edit APN afterwards.
If it doesn't work then buy or borrow a Freedom Mobile sim card as suggested.
