Cannot accès Voicemail
onceinrome
hello, when I try to access my voicemail, I get a failed called message.
Any ideas on how to fix that ? Thank you !
G
7 REPLIES 7
G
Hello @onceinrome
Have you set-up your voicemail yet? IF not, see here to set it up:
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
Other voicemail features for reference:
https://www.publicmobile.ca/en/on/get-help/articles?category=phones&subcategory=voicemail-features
onceinrome
solved. thanks so much for the reply. the saved voicemail number was incorrect.
onceinrome
the saved voicemail number was wrong. thanks for helping out.
onceinrome
thanks, you are absolutely right. the saved voicemail message was wrong.
 @onceinrome : Are you new here? If you dial 17785804001 what do you get? What happens you dial 611?
Your phone displays a message or you hear an audio message that is played back to you?  Which number are you trying to call to access your voicemail?  I think that is possible that the phone number isn't saved on the phone properly or possibly has a mistake in it.
@onceinrome  did you try to access the voicemail from a landline?   Call yourself  and enter *  to skip the greeting, then enter PIN
do you always have trouble access your voicemail from your mobile phone or just started today?
