phone number not working
GerryKelk
It has been a couple of hours since we signed up with Public.  We are still not able to make or receive calls.
2 REPLIES 2
will13am
@GerryKelk, are you able to go into the account and check status?  The other problem might be a stuck port as already suggested.  If you submitted a port as part of activation and something goes wrong with the port, you might not have a number to work with.  So plan features requiring the phone number won't work.  That said, does data work?  That is not affected by a number port.  It will work as long as the account has been properly activated.
NDesai
@GerryKelk Did you port in your number? Do you get signal on your phone with Public Mobile sim?
