the phone can't make a call
Cypm
since this morning the phone can\t make a call it is no long distance call however i just call the local please relove the problem for me have send private message this morning also however so far nobody reply yet.
@Mary_M
Mary_M
Retraité / Retired
Retraité / Retired
@@Cypm,, it seems like your plan did not renew - please view your private messages for more details 🙂
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
xCameron94x
by local do you mean the same province? Calling should work. If you have an extra phone can you put the SIM in that phone and see if there's a similar issue. If it is, its most likey a SIM issue.
Did your plan expire and you forogt to pay your bill? This could also be a factor
Mary_M
Retraité / Retired
Retraité / Retired
Good morning @Cypm,
thank you for reaching out to us!
I'm sorry to hear that you have experienced some difficulties using your services - you've come to the right place for help. Rest assured that I have received your private message and I will be respond shortly.
Regards,
Mary
