07-09-2022 10:39 AM - last edited on 07-10-2022 12:23 AM by Dunkman
cant find my pin information. do i even have a pin
07-09-2022 02:36 PM - edited 07-09-2022 02:36 PM
You would have create your own PIN number when you activate your SIM.
Did you activated the SIM or was it done at a PM retailer?
07-09-2022 10:44 AM
@britaniola12 You might have got a PIN from the text in the beginning when you joined,
If not, you will have to open ticket with PM Support to have that reset:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Reset PIN", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
07-09-2022 10:41 AM
@britaniola12 yes you got one when you activated , if you lost it you will need to contact customer service
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
07-09-2022 10:41 AM
You would have chosen your PIN when you first activated your SIM card. Public mobile in the past use to send a text with your PIN.
If you don't know your PIN, you will likely need to contact customer service agent to reset your PIN.
