when i transfer my phone number typing wrong account nr
adammus1
hi when i transfer my tel nr from old provider i typing wrong account nr and my phone dont working what i can do to corected my account number
2 REPLIES 2
Cyber
@adammus1,
You account from your old provider must be in good standing and paid while you are doing the transfer.
You can fill the porting form from your self-serve account here.
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/msisdn-swap/
If the porting fail, you have to send an email to Public Mobile.
How to send an email ?
Click on this link : https://publicmobile.ca/en/on/contact-us
Then, at the bottom right of the page, click on "Email away" button.
  - Choose ""
  - Choose ""
  - Pick the option that matches closest to what you’re looking for help with.
Porting a mobile number takes around 2-4 hours.
Porting a landline number takes 7 to 14 business days.
Martin
Legend
Legend
Hello,
Contact your old service provider as soon as possible to have the mistake corrected, or send a web mail to Public Mobile. Click on Contact Us on this site's home page. Another page will open with Email Away on it. Click that. Another page will open with a web form on it. Complete and submit it to Public Mobile. In about 2 or 3 business days, an agent of Public Mobile will contact you.
Until the mistake is corrected, you can choose a Public Mobile number free of charge. Log into your self serve account, click the tab called Plan and Add-ons, and then the tab called Change Phone Number. Choose a number for your province and city.
Do NOT cancel your old number. When it is successfully ported, your old account will be automatically deactivated.
Good luck!
