Can I Call from Europe or Middle eastern countires
b4basir
Hi
Actually i am going to Europe and Middle eastern countires. Can i get calls there or use the internet?
pakmode
Also - make sure your phone is unlocked before you go over.
Acekiller
you will have to get a roaming sim card, like knowroaming or freedompop
chakri264
Unfortunately not. You can only use PM in Canada and in US given that you have ong distance add-ons. Hope it helps
nishufan
Hi @b4basir
  PM only offers US roaming services at this moment. You can forward your number to a Fongo number, and use Fongo via Wifi or local sim to receive calls. Thanks
will13am
I don't believe Public Mobile offers roaming in any of those countries at the moment.  You will have to resort to apps that do calling with data unfortunately.
