11-21-2022 03:47 PM - edited 11-21-2022 05:00 PM
I have weird characters showing up on my call display from callers that are not in my phones contacts.
I have an Sumsung Android phone. I have tried to find a solution on google?
The calls on my call display with weird characters are legitimate callers that I know!
When someone calls me that is in my contact list on my phone, it shows up correctly on the call display. When someone calls me that is a legitimate caller but not in my contacts the call display shows their name in a weird font.
11-21-2022 05:02 PM
HI @Voltman
Try this
on your phone , phone dialer app, clear cache and reboot the phone and see if it fixes it
If not, then use your PM sim in another phone and check if you have the same problem
Use another sim card on your phone and see if that has the problem too
11-21-2022 04:59 PM
I still have the same problem! when someone calls me that is in my contact list on my phone, it shows up correctly on the call display. When someone calls me that is a legitimate caller but not in my contacts they call display show their name in a weird font.
11-21-2022 04:48 PM
11-21-2022 04:46 PM - edited 11-21-2022 04:51 PM
@Voltman wrote:I have weird characters showing up on my call display from callers that are not in my phones contacts.
@Voltman You have couple of different statements in your first postm bolded, above. If you're concerned about unknown callers (not in your phone contact), then don't respond as already mentioned and you can block them if needed.
11-21-2022 04:42 PM
My contacts show up correctly on the call display!
11-21-2022 04:36 PM
@Voltman So these legitimate numbers recently started displaying with extra characters on your phone? It does seem odd but you've received some suggestions about the possible reasons why this is happening. You could ask your contacts if something has changed on their end or try removing the contacts and adding them again as suggested by @hTideGnow?
11-21-2022 04:24 PM
I have answered the calls and they are from legitimate callers that I know!
11-21-2022 04:22 PM
@Voltman Okay, now I'm a bit confused. Either these callers are legitimate (with weird characters?) or they're spammers/scammers or the legitimate numbers (in your contacts) have had their number spoofed?
Have you answered these calls and found the person is a legitimate caller?
11-21-2022 04:08 PM
I have edited my post :
"The calls on my call display with weird characters are legitimate callers!"
11-21-2022 04:06 PM
Sorry I had a ? at the end of the statement. It should have read:
11-21-2022 04:03 PM - edited 11-21-2022 04:04 PM
@Voltman Sometimes legit callers try to hide or block their numbers when calling too. It's not unheard of.
They just found out a way to add wierd characters in place of numbers.
11-21-2022 03:58 PM
HI @Voltman honest, that was a question mark at the end and I wasn't sure you were asking a question or was it a statement
Try to delete the contact, reboot the phone and then re-add the contact and have the person to call you again
11-21-2022 03:56 PM
As I said "The calls on my call display with weird characters are legitimate callers? "
11-21-2022 03:55 PM
As I said "The calls on my call display with weird characters are legitimate callers?"
11-21-2022 03:52 PM
@Voltman If you don't recognize the number, then don't answer and if it's important they will leave a voicemail or text which you can check and decide whether to call them back or not.
However, usually any numbers with characters are more than likely spam or scammers. You can block these numbers on your phone, but they will more than likely just call again from a different number.
11-21-2022 03:51 PM - edited 11-21-2022 03:52 PM
@Voltman It's just how callers try to hide their where abouts when calling and scamming around.
11-21-2022 03:51 PM
Never a good idea to answer any calls that you don't recognize the caller. If it's legit, they'll leave a message and you can call back if you want.
Once you answer these types of calls, the scammers know you'll answer and keep hounding you.
Just don't answer.
11-21-2022 03:51 PM
HI@Voltman
is that from a contact you know?
or it might be an overseas caller?
It could also be a spam call and they purposely put the caller id what way
11-21-2022 03:50 PM
@Voltmanweird characters and numbers are not worth answering..
11-21-2022 03:49 PM
This could be the result of an error in the transmission of the infromation, or could also likely be an example of a callers trying to hide where they are really calling from.
