11-05-2020 02:49 PM - edited 01-05-2022 05:23 PM
11-17-2020 08:29 AM
@kg3 wrote:Friend used The Community to solve the problem herself.
Thanks to all who replied.
Keith
Glad to hear. Care to share the outcome in case it might help someone else in the same boat?
11-13-2020 11:52 AM - edited 11-13-2020 11:52 AM
@kg3 that's what this forum is all about 🤗 You're welcome!
11-13-2020 11:51 AM
Keith
11-05-2020 04:12 PM
We need way more detail (phone? plan? self service account status?) before we can help you.
11-05-2020 03:41 PM - edited 11-05-2020 03:42 PM
In order to get data working, the APN settings must be correct and enable mobile on phone.
Restart phone with PM SIM Card inserted to let phone to configure the APN settings automatically. If restart doses not setup the APN correctly, manually configure the APN as suggested above.
If you friend has a LG phone, do a network reset after changing provider before data working again.
11-05-2020 03:23 PM
What phone? What plan? Is cellular data on on the phone?
11-05-2020 02:55 PM
@kg3 What is the make and model of their phone?
11-05-2020 02:51 PM - edited 11-05-2020 02:52 PM
Is it an android phone? What kind of phone do they have? What plan are they on?.
Check the APN settings. Add a new apn.
Save and reboot.
If they don't work try these.
