07-01-2018 11:25 AM - edited 01-04-2022 06:20 PM
Now if I call my cell number from another line then as soon as I reach greeting press (star) key prompted to enter VM password I get allways the message INVALID PASSWORD. Do I need to do that via cellphone publicmobile voicebox call first ? Unfortunately I have no cellcoverage where I live and need to check my voicemail from Landline.
07-01-2018 03:06 PM
@Luddite wrote:Are you sure you've created a 10 digit voicemail password? I thought they were 4 digits. The 10 digit phone number is your mailbox number not your PIN.
After you "Reset Voicemail Password" your password will temporarily be your entire phone number, for example: 905-333-4444
After you enter your phone number as your password, you will be able to pick a new voicemail PIN number. ![]()
07-01-2018 12:34 PM
You may have to wait until you have cellular access: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Voice-mail-setup/m-p/88427#M10496.
If you remember the 4 digit PIN you gave when creating your account try that.
07-01-2018 12:30 PM
07-01-2018 11:33 AM - edited 07-01-2018 11:37 AM
To access your Voicemail after Password Reset you have to do that from your cell phone
