voice mail
fidothecoolest
Hello tech folks
I can't access my voice mail
Kindly guide me step by step how to set it up and my phone changed the settings to *86 and that is not allowing me to access my voice mail
2 REPLIES 2
@fidothecoolest so, press and hold 1 does not get you to voicemail?
Check the list of number from here
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
pick one and call , if it works, you can program it as your voicemail number on your dialer settings
More details for VM setup here
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
Public Mobile doesn't use *86 to call voicemail. Please call your voicrmail retieval number, your own number, or hold down the 1 key.
