04-22-2022
01:36 PM
04-22-2022
05:45 PM
computergeek541
My calls to voicemail fail. I get a "Error performing request. Unknown Error" message. It used to work fine. I made no changes.
04-22-2022 08:31 PM
@carlmccrosky - Try restarting your phone, then try accessing it.
If still issues try performing a Reset of your device's Network Settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
04-22-2022 02:39 PM
@carlmccrosky Are you on the $10 or $15 plan and all your minutes? Calling voicemail counts against those plans
04-22-2022 02:12 PM
Check what vmail number is assigned to 'voice mail calls'.
Can you access vmail dialing access number?
Try one of these:
04-22-2022 01:50 PM
Do you access it by dialling a number or just pressing voicemail on your phone?
04-22-2022 01:44 PM
Try dialing 1-778-580-4001. It's likely that the access number has changed. Can you drill down in your settings to find the voicemail access number currently set up?
