video calling
stevencofsky
video calling icon grayed out. cannot make video calls
hi @stevencofsky
you just need to install the correct app back
depends on what your friends use.  Whatsapp is the best.  Or you can use Microsoft Teams or Zoom
stevencofsky
I don't remember what app i was using. whta do you recommend as a good app for video calling?
stevencofsky
it worked fine with my moto 5 G5 2022 but not with my moto 5 G5 2024.
Yummy
Nothing to do with PM as PM provides mobile service (calls/sms/data).
Look at issues with your 3rd part app.
hi @stevencofsky
what app you are using? sound to me it is an app issue and not network
make sure your mobile data or wifi is turned on..  Make sure data works
