utilisation
micheldrolet1
you say I used all my minutes for the period ending oct. 16.  That’s impossible. Please verify.
2 REPLIES 2
umnikke8
If you have a plan with unlimited minutes or otherwise have minutes available and you aren't able to make calls, contact customer service through the expert messaging system.
@micheldrolet1
PM is a self-serve online service so just login to your account on the PM app or website and it will show your current data usage.
Also, disable your data counter app since PM is on a 30 days cycle and not monthly which the app utilizes.
