05-26-2023 02:26 PM
Does the add-on and or promo data that I have click in automatically when the data on my monthly plan is used up? Or do I have to do something to make sure I get the promo or add-on data?
05-26-2023 02:40 PM
@ConstanceSus Absolutely so long as you have it it will kick in with no interruptions
05-26-2023 02:38 PM
I sure hope so as I will be going on a holiday soon and it is important that I have data
05-26-2023 02:30 PM
HI @ConstanceSus it will be automatic, no extra work to do
But login My Account using Incognito/Private/secret mode to confirm you still have the data
and, make sure you disable data limit on your phone, that could block further data used
05-26-2023 02:27 PM
@ConstanceSus It should just kick in a automatically when your plan data bucket is used up , or if you just purchased it because you ran out you may need to reboot your phone
