6 hours ago
New subscriber how do I know if the referral code worked when I signed up as a new subscriber?
3 hours ago
I've been told it takes two to three business days I'm you as well. I'm also waiting to see if I'm getting mine 😊
5 hours ago
Then check My Account tomorrow using Incognito mode. You should see a $10 there
5 hours ago
@komk, it's still very early then, check in another day or 2. If it's not there by Friday reach out to a CS_agent and they'll take care of it for you. Most times it's in there with 48 hours. For my wife it was not there after waiting a week so we had to contact the agent and they added it afterwards
5 hours ago
thank you.
5 hours ago
i just joined with a new account last night.
5 hours ago
HI @komk
how long you subscribed? you should see a $10 in your My Account as Available Fund within 72 hours, usually earlier
and the one who referred you would get a text as well
5 hours ago
@komk it typically takes up to 72 hours for the $10 credit to appear in your account. If that time has passed and you are not seeing it in your available funds then contact a CS_agent as they will apply it to your account. Just click on the small orange circle in the bottom right corner and type: Customer Support Agent
6 hours ago
If you enter a wrong code, the system will show you immediately.
and you will see a $10 credit showing up on your My Account within 72 hours
