us roaming with voice only
barryrg
I have tried everthign stsed here but to avail.  It is a Samsung A20.  The only time I get anything close to working is when I manualy select T mobile.  I can then dial 611 and get inot the self service.  It tells me there I have the 200 minute us roaming voice.
PAULRANG18
You will need a US roaming add on while in the US. With other plans, you can only call or text while in Canada.
Stay Safe!
ShawnC13
The 200 minutes is for calling to Canada or the US while located in Canada.  You need a 10 Roaming add-on if you want service while visiting the US
The 200 minutes you mention is only for while in Canada. It doesn't say roaming either. You need a roaming add-on.
