04-11-2023 12:08 PM
04-11-2023 12:18 PM
So what seemed to fix it?
04-11-2023 12:18 PM
just so we know if asked in future...what did you do to make the US Roaming work ?
04-11-2023 12:16 PM
04-11-2023 12:14 PM
thank you so much for all your help.
04-11-2023 12:13 PM
@Mikela14 did you just get the Talk and text roaming? did you buy the data roaming as well?
if you don't have data roaming, make sure you are sending traditional SMS and not iMessage or RCS. iMessage/RCS both needs mobile data or Wifi to work. Only tranditional SMS can be sent using Talk & Text roaming without data roaming
And make sure you have T-Mobile connected. If not, try to use Manual network connection and pick T-Mobile from the list
04-11-2023 12:11 PM
text messages still not coming in with roaming on
04-11-2023 12:11 PM
Did you buy a roaming add-on? Did you receive the welcome to US text? Is this an iphone? Picture text or plain text?
04-11-2023 12:09 PM
