urgent help needed - number ported to public mobile, eSim deleted and can't reactivate - shows SOS
Catarina_Spence
I recently ported my phone number to Public from telus and activated an eSim for the service. I received confirmation that the porting process was successful from telus end but there was a sync issue from public.
however, I accidentally deleted the eSim profile from my phone. Since then, my phone shows SOS only and I am unable to make or receive calls or texts.
when I try to add the esim back using the original activation QR code I get a message saying my number cannot be transferred or activated again. I am concerned that deleting the eSim may have caused my number activation to be blocked or stuck.
I want to clarify that:
the number porting process was fully completed and the number is now with Public Mobile
I currently have no active eSim or Sim installed on my phone, which is why I have no service.
I need help to reactivate my number on a new eSim profile so I can use my phone normally.
Please assist with reissuing a new QR code or resetting my account activation if necessary.
I NEED HELP
Catarina_Spence
Thank you!! Definitely hoping they can send a new QR code and get my original phone number before I loose access to everything especially because its my work number 😞
@Catarina_Spence  unfortunately timing is kinda bad support hours are 9am-10pm EST most likely won’t get a re ply till tomorrow morning some time , but I have seen in the past some got lucky with reply through out the night before , best of luck 🤞 but definitely sometime tomorrow you will get reply from customer service
Catarina_Spence
thanks, I understand but I was freaking out because it was past 6 hours already. Now im stuck with SOS mode and can't reactivate the number without help. hoping they get back to me quickly
@Catarina_Spence
you shouldn't have deleted your esim.  It was likely just an esim setup on the device or a sim provisioning issue and both could be resolved quickly
now that you have deleted your esim, you have no choice but to engage support to try to get a new esim or change to physical sim first.  Please private message CS Agent at:
@Catarina_Spence
send  a  private message   To CS_Agent
