unsolicited verification code messages
frog2
Can anyone explain why my cell phone is receiving unsolicited verification code messages and if so what I can do to stop them? Many thanks
16 REPLIES 16
Gerry99
DO NOT REPLY to that text message.
it is 100% a scam, and they are hoping for someone to reply so they can attempt a hack
Gerry99
It has happened to me also, 3 separate times now. The last was at 2:48 this afternoon
HI @Genealogist   it could be a scam, it could be sent by mistakes (people can put in wrong number)
Just ignore   🙂
Genealogist
Blocked and deleted.
Genealogist
Yes, I got a numerical code too - from (833) 994-0038. Thanks!
MurphyT
I have received 4 today from the same number. Mine is showing its google verification. I was thinking of blocking the number but since I actually have google accounts, I don't want to block the number.
It could be that the person who had this phone number before me is trying to get into an account they had so I will ignore it. I am sure it will stop sending soon. lol
frog2
Thanks
dabr
@frog2   Another option you can consider if you find that you're getting too many unsolicited calls/messages, you can change your number once every 30 days for free.
frog2
Thanks for the suggestions - makes sense. Cheers.
frog2
Thanks  RossN- this possibility makes sense. Cheers
@frog2 block them individually. Stay safe.
RossN
@frog2 wrote:
Numerical codes - the last one if from the number +1 833 994 0036. Thanks
@frog2 @t may be from someone who had your number before and forgot to change there info it has happened to me in the past unless you change numbers I can't see doing much about it
Lowufo
Sounds to me like someone else had your phone number in the past and they are trying to sign into a website like the bank etc that uses two part authentication.
dabr
@frog2   Are you perhaps asking about a text message from 5179 regarding free data/mins?  Otherwise you'll need to provide a bit more information as already suggested.
frog2
RossN
@frog2 hi what type of codes are you receiving?
