07-18-2023 11:56 AM
Just received notice that my subscription has been placed on hold due to an unresolved payment issue.
There have been no changes in the way I pay this account. Why can't you talk to an actual representative?!
07-25-2023 01:14 PM
@Blizzie_Thumdet- Excellent details. It would seem that that text was sent in error. If your services are working then ignore it. And I don't think you need support other than to add your name to the list of customers that got this erroneous text.
07-25-2023 01:10 PM
I wanted to add that I am also experiencing a similar issue as @ARC44.
A timeline for others that may be experiencing something similar:
Items of note that may have an impact:
For those interested, the text message from Public Mobile states:
Public Mobile here,
Please note your subscription has been placed on hold due to an unresolved issue with your payment.
To resume your subscription, simply log into the Public Mobile app or My Account to update your payment details. Alternatively, you can dial *611 to make your payment.
Thanks for posting this @ARC44 and sharing the link @dust2dust , and hopefully this resolves my issue.
07-18-2023 02:48 PM
Done, jeez, thank you. I am the worst with this stuff.
07-18-2023 01:06 PM
If the username you chose here is your number (if it is you should change it) then I just checked it and it seems to be active and due on Aug 12th. You got a text from 611 for that test. Your welcome 🙂
07-18-2023 12:59 PM
Lifesaver! Message sent, thank you for this.
Cheers
07-18-2023 12:50 PM
best is to login My Account to confirm
Or you can also call *611 from your phone and it will confirm you the amount due date
07-18-2023 12:43 PM - edited 07-18-2023 12:47 PM
@emilymccardle, @ARC44 - Are services working? Maybe it's just an erroneous message.
Adding - the ticket system is broken. Use this link
07-18-2023 12:41 PM
I'm super confused! It's the same card I had set up, never an issue, doesn't expire until 2024. I go in to my subscriptions and it says next payment due mid August. Can't put in a ticket because it's in a constant 404 error state. I really wish you could actually reach out to a rep
07-18-2023 12:39 PM
Thank you dust2dust, no issues with my card at all.
07-18-2023 12:10 PM
i also just received this message and my payment isnt due until the 23rd? very confused.
07-18-2023 12:06 PM
Did you have a credit card problem recently and maybe the bank reversed some charges that might have included here?
Or maybe just autopay failed from some reason. You'll need to make a manual payment to reactivate the service.
