02-26-2021 03:35 PM - edited 01-05-2022 05:26 PM
looking at a new plan
Under province wide plan . What is unlimited province wide-minutes2 ? the 2 is? The first part is easy to understand unlimited province wide
02-26-2021 04:52 PM
There's no good reason to choose the province wide calling plan ATM when the canada wide plan is still being offered at the same price. Choose the canada wide option and you will be grandfathered in. If you decide to change plans in the future you can worry about the difference then....and choose to change your plan on next renewal unless you need more data now.
@Anonymous
Hmmmm.....not a critic you say......I think I could successfully debate that statement. Lol...
02-26-2021 04:42 PM - edited 02-26-2021 04:44 PM
02-26-2021 04:38 PM
@XionBunny : not a critic...just goofin' around that's all 🙂 Makin' a joke.
02-26-2021 04:25 PM
@HALIMACS It's "toe the line", you'll always get a critic 😛 , this company isn't here to care about us, but they will always care about the share holders though, cause money.
02-26-2021 04:08 PM - edited 02-26-2021 04:09 PM
@HALIMACS : My comment is entirely directed at the company. I'm just putting up an unsolicited opinion. 🙂
And how heavy are those lines that you're towing? Check your towing capacity. 🙂
02-26-2021 03:57 PM - edited 02-26-2021 04:00 PM
@Anonymous wrote:I don't approve of the wording "home province". It's only "home" in as far as your phone number belongs to that area code of that province. I prefer to say that you can call provincial numbers of whatever province that you're in.
Thus my use of quote around 'home'.
That's what PM used in their description - so for sake of consistency and to prevent wording discrepancies for OP, thought better to tow the line (geez, can't believe i just said that -- what have i become)
[EDIT: I do concur better word than 'home' could have been utilized to fit real-life situation of a person's current whereabouts when physically making the call.]
02-26-2021 03:54 PM
02-26-2021 03:46 PM
The description is included in the details. Basically, the difference between Canada-wide (which is still available on a Limited Time basis) and the Province-wide is that Public Mobile believes customers might like choice between the two and will soon have different price points for each option.
In reality, it's a price increase on the prior plans masked by a new string of plans with lower flexibility in calling outside your 'home' province.
Let us know if we can provide further details.
Thanks.
02-26-2021 03:45 PM - edited 02-26-2021 03:51 PM
@gq wrote:that sounds all good for unlimited but why the 2 in the wording is that a incoming outgoing or a time frame type restriction
Hi @gq #2 is the reference number of the Plan Details
Taxes are extra. The account must have sufficient funds to cover the total cost each month.
1 - Plans with 3G data may reach download speeds of up to 3 Mbps, with the coverage and reliability of the LTE network. Speed and signal strength may vary with your device, configuration, Internet traffic, environmental conditions, applicable network management and other factors. For a description of Public Mobile’s network management practices, please see https://www.publicmobile.ca/pdfs/WirelessVideoExperience_Optimization.pdf
2 - Province-wide calling means you can make outgoing calls to any number within your home province. Plus, you’ll receive all incoming calls across Canada regardless of the province they’re from. If you’re travelling to another province, you can make Province-wide calls while you’re there. You’ll still receive unlimited incoming calls. But you won’t be able to call your home province while travelling and will need a Long Distance add-on.
I hope this helps
Welcome to Public Mobile
RosieR
02-26-2021 03:41 PM
02-26-2021 03:37 PM - edited 02-26-2021 03:41 PM
This means you can call anywhere within your home province, and talk for as long as you want.
If you select one of the Provincial talk plan details, say $25 for 500MB 3G (publicmobile.ca)
and expand on "Offer Details", #2 reads as:
