unable to change plan
sebastiaan1978
Tried changing my plan and its not showing any options to pick from. Tried for pc and mobile device with no luck.
2 REPLIES 2
@sebastiaan1978 did you try Incognito mode? if that fails still, you might want to try later
do you need olab change urgently? if so, open ticket with PM support and ask them to manually change for you
dust2dust
Hmmm good of you to try multiple devices but it works for me. Had those devices been in the account recently before this?
