08-09-2016 05:50 AM - edited 01-04-2022 02:59 PM
I have a 337 area code and my wife (also on PM) has the same area code. However, we can not call each other. We have province wide calling and we are definitely within the province. When we try calling, a message says we do not have a long distane add on.
Is anyone having the same situation/problem? Is there a known solution?
08-25-2019 04:13 PM
If this is the same issue as the op, you may have to msg a moderator like the op did.
Contact @Moderator_Team
It can take up to 48 hours for the team to respond to your concerns.
I you have a different specific problem, you should start your own thread for visibility.
Try to put 1 in front of your number, check if you have calling minutes left, start your own thread and then message a moderator.
08-25-2019 04:10 PM
@patrickletalnet hi you can buy a 500 minute add on for 5 dollars if needed
08-25-2019 04:08 PM
@patrickletalnet hi can you check in your self serve account under data and add ons see if you have any minutes left if none showing then thay are all used up
08-25-2019 04:05 PM
Hi there, i cannot call outside my area, i have the 15$/mth plan which include 100 minutes canada wide, can someone help me out with this?
thanks
08-09-2016 09:54 PM
08-09-2016 09:30 PM
did this get solved? I'm having the same issue
08-09-2016 04:02 PM
Please view your private messages once you get a chance.
Thanks,
Shazia
08-09-2016 02:43 PM
I think I may have mixed up my definitions of AREA codes and PREFIXES. Anyway, my number is 226 337 XXXX. this would be in the guelph area. The number I am trying to call is also 226 337 XXXX, which should work (at least with the way I understand it).
08-09-2016 02:29 PM
@paotranq you have piqued my curiosity--I wasn't famiilar with 337, so I googled it, and it appears to be for Louisianna, in the southern United States: https://en.wikipedia.org/wiki/Area_code_337.
I'm curious, in what part of Canada do you live? (You don't have to be very specific--for example, I'm in the greater Vancouver BC area). And in fact feel free to ignore me to tell me to mind my own business. I'm just curious. 🙂
08-09-2016 12:53 PM
PM sent
08-09-2016 09:25 AM
Good morning @paotranq,
I'm very sorry to hear about this,
This shouldn't happen since you are both with the same area code and same talk plan, I will need to look into this and see what is causing this to happen.
Can you please send me both phone numbers via private message?
Thanks,
Shazia
