12-20-2022 11:05 AM
12-20-2022 11:39 AM
It's easy, just follow this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
12-20-2022 11:22 AM
i have opened a ticket
12-20-2022 11:17 AM
Use the Chatbot Simon to get a service ticket started first.
Or you can also send a private message to CS_Agent for help.
12-20-2022 11:16 AM
@kzeleschuk are you able to login to My Account at all? You should be able to change plan easily yourself
But if you need to engage agent, please open ticket with PM using Chatbot (method 1). If you cannot login My Account, then use Method 2 below:
Just open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
12-20-2022 11:15 AM
i need to first create a plan in order to log in
12-20-2022 11:13 AM
Are you trying to activate here as a new customer or are you an existing customer trying to change plans?
If a new customer, you'll need to acquire a SIM card and click activate on top once you have a credit card and email address to use.
If an existing customer looking to change to a different plan, log on to self-serve then click plans and add-ons on the left and select the plan you wish and choose to change it on next renewal (otherwise you will lose whatever's left on your current cycle)
12-20-2022 11:13 AM
THANKS. i need a customer agent support now
12-20-2022 11:10 AM - edited 12-20-2022 11:14 AM
To change your plan, you'll have to login to your account first. Then choose change plan.
Login to your account using a browser in incognito or private mode first.
If you don't have a self service account yet, you'll have to reach out to a Customer Support Agent, to have them create one for you.
Use the Chatbot Simon to get a service ticket started first, to get help from a CSA.
