03-06-2023
11:43 AM
03-06-2023
01:46 PM
computergeek541
I bought data for 15 days in the USA on feb 22 when i crossed the border my data did not work till i crossed back into canada it was very frustrating not having data i paid for i would like a refund
03-06-2023 12:26 PM
@edverhoeven wrote:what do i enter as contact
We are customers and members like you here on the forum. The other members have included methods to contact public mobile representatives, which can also be found in the GET HELP articles here:
All support is through messaging, so you will need to submit a ticket by either the 2 methods provided.
Were you able to be successful to submit a ticket?
03-06-2023 11:56 AM
@edverhoeven maybe just message CS Agent directly here then
03-06-2023 11:56 AM
03-06-2023 11:54 AM
i do not know how to follow these instructions
03-06-2023 11:46 AM
HI @edverhoeven
We seen people with problem using roaming and PM agent was able to make the refund. Please submit a ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
03-06-2023 11:44 AM
@edverhoeven sometimes, you might have to manually select T-Mobile from your network selection instead of leaving it with automatic
Usually if the roaming was not used, PM would be able to do something.
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
