yesterday
I have a physical sim on my old Samsung phone. I have a new i-phone 17 pro which does not use a physical sim. I want to use my i-phone with my old number. How do I convert it to e-sim
8 hours ago
you don't need to do anything, the eSIM is installed after you click Purchase
just check Settings-> Cellular screen and it should be there.
8 hours ago
Just had a look at your previous post from yesterday.
Once you download the PM app on your new phone and purchase the eSIM. Once the eSIM is installed (automatically), your phone number is attached to the eSIM and your phone number has then be transferred.
The old SIM card will be inactive and your old phone will be inactive.
P.S. I will combine this post to your initial post from yesterday.
8 hours ago
existing customer and just transferring your PM phone number/account to new phone? I have bought the esim but cannot get the prompt to install
8 hours ago
hi @sebon2025
if you bought it, the app installed for you already
just go to Sim Manager or Settings->Cellular and check if PM sim is showing there. Make sure the Public Mobile sim is enabled , or Turn on this line option is toggled on. Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work
if any issues, ask PM to help, submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
8 hours ago
I have purchased the esim but I need to know how to get it installed
9 hours ago
Download Public Mobile ap on the new phone and login. Then go to Account -> Purchase Sim card and choose eSIM and buy and install
if your last eSIM was bought 15+ days ago, it should be free
9 hours ago
Are you a new customer? Just activated new eSIM/account and now want to transfer your number from another mobile company?
Or are you an existing customer and just transferring your PM phone number/account to new phone?
9 hours ago
I have downloaded the PM app and purchased the e-sim. on my iphone 17 pro. Please what do I do to have my old number transferred to the e-sim on my iphone
9 hours ago
hi @sebon2025
the number is with your account.
so, all you need to do is to Download PM app on the phone, login PM app using the same email that you have been using. After logged in, you should see your current plan. Go to Account page, click Purchase sim card and choose esim
9 hours ago
I have downloaded the PM app and purchased the e-sim. Please what do I do to have my old number transferred to the e-sim
9 hours ago
yesterday - last edited yesterday
Simply, just download the PM app on the iPhone 17 Pro. Login to your account and go to Account tab-Purchase SIM Card and it will give you the option of an eSIM.
You can have the 2FA code sent to You email by clicking on Resend Code or Didn’t Receive Code to access your account on the app.
yesterday
hi @sebon2025
What you need to do is to download the PM app on the new phone, login to the app. If you have trouble getting 2FA code via text, click Didn't receive code or Resend code and then choose Send email or Send voice message to get the 2FA code via email or voicemail (you can call yourself from another phone to retrieve the 2FA voice message)
After you logged in the app, go to Account page and choose Buy sim card and select eSIM.
