03-24-2022 11:12 PM - last edited on 03-25-2022 12:59 AM by computergeek541
recent transfer of my PM account to another provider, but have not received SMS yet. When do I received a text from PM?
03-25-2022 12:07 AM
The text will go to the Public sim. Put it back in and wait for it.
03-24-2022 11:57 PM
Most likely wasn't a successful port then, you would have to retrigger it to get that message because it should be right away. Especially if everything is working still on PM that wouldn't be the case if your number was with your new provider
03-24-2022 11:39 PM - edited 03-24-2022 11:39 PM
@Birdlifelist1 wrote:yesterday evening, yes I'm still able log on. Service still works
@Birdlifelist1 so, your PM Service still working?
Please call your new provider tomorrow morning and confirm if you have provided them all the required information, like your PM's account them. Also, ask your new provider to re-trigger the text process and check if you get the Porting Authentication text on your PM SIM. If you still not able to receive the text, then open a ticket with PM using this direct link:
https://urlshortner.tiia.ai/Lc9xk8
03-24-2022 11:28 PM
03-24-2022 11:23 PM
@Birdlifelist1 When did you try to port out? Are you still able to log into your PM account? Does service still work or have things stopped working?
03-24-2022 11:16 PM - edited 03-24-2022 11:16 PM
@Birdlifelist1 Should be pretty much instant when the transfer is submitted to new provider. Than you have 90 minutes to reply to authorize the transfer.
