12-02-2020 01:12 PM - edited 01-05-2022 04:20 PM
12-02-2020 08:02 PM
@JK8 ok JB 😉!
12-02-2020 01:21 PM
due to a lot of scams etc, I have been told that we need to have a moderator do the porting of numbers. You can use the simon bot on the bottom right of the screen and contact a mod by putting in "port" and simon will send you a link to contact a moderator.
12-02-2020 01:15 PM - last edited on 02-03-2021 07:58 PM by Ioana_R
To port your number call our Porting Team at ***
Porting Your Number Into Public Mobile
If you are porting your number into Public Mobile, for additional security, your previous service provider may also send an SMS text to validate the transfer. Follow the instructions in the message within 90 minutes to approve the number transfer.If you have missed the 90 minute window to respond, we will send you an SMS with instructions on how to re-initiate the transfer by calling our Porting team.The SMS will read as follows:Public Mobile Msg: The request to move your phone number to Public Mobile has timed out. Don't worry, you can easily re-initiate the transfer. Please call our Porting Team at ***to authorize your number transfer
Tips:
12-02-2020 01:14 PM - edited 12-02-2020 01:27 PM
@khayamsamon wrote:fido old tel num to public mobil
fido tel num :
public mobil tel num :
thanks
This is a public forum. Choose 3 vertical dots in top right of your post and edit your numbers out. Everyone can see your numbers. You are opening yourself up to fraud.
