top ups
miriamb
I paid for wrong top up. I bought usa data/long distance top up. I would like a refund for that, or an exchange for something i could use would be awesome.
2 REPLIES 2
@miriamb   Possible.  Plese message support and ask them to reverse the transaction so you can re-buy the correct one:
HI @miriamb
CS agent likely able to either swtich it or put the fund back to your account, please open submit a ticket:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
