12-03-2024
05:03 PM
12-03-2024
05:06 PM
computergeek541
12-03-2024 05:14 PM
It depends on the type you purchased. Some people say some vouchers take 24 hours to show up. If its been more than that and you added it yourself, as suggested ask agent to check
12-03-2024 05:10 PM
if the fund is used for reactive service, reboot phone and test
and you can call 1855-4PUBLIC from another phone to check if the available fund is there
Lastz ask PM to check ,
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
12-03-2024 05:09 PM
no i dont
12-03-2024 05:07 PM
Yeah it doesn’t show up on my account
12-03-2024 05:06 PM - edited 12-03-2024 05:06 PM
@michelle25 clear cache and look again. When was it added? Do you not see extra money in available funds?
12-03-2024 05:05 PM
hi @michelle25
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
