02-04-2015 10:24 AM - edited 01-04-2022 12:32 PM
The sim card that came with my Huawei phone doesn't work. I have tried many times to activate it, but it does not work.
Phones
03-09-2015 09:35 AM
03-09-2015 09:23 AM
sorry, that means "check phone" function under "get started" does NOT work well. does it?
02-18-2015 10:15 PM
Thanks All,
I just want to know why I could get PASS once I did phone check.
I am not a professional person for wireless network product, that is why I went to get started and did phone check before I ordered SIM card
02-17-2015 05:11 AM
02-16-2015 05:43 PM - edited 02-16-2015 05:45 PM
This phone is tricky because it has an option, if it's checked SIM won't work, Go to Settings/Mobile Networks/Network Settings/if you see check mark next to "Use Only 2G Networks", take it out and try again.
02-16-2015 04:49 PM
That's true. But also, even if phone supported 3G/4G specs, if it doesn't support the frequency, 850 MHZ, example, or any Frequency specifically on Telus/Bell Network, Even if 3G/4G, won't work at all. Ensure handset supports all frequencies above the 3G/4G Network
02-12-2015 08:25 PM
02-12-2015 08:15 PM
please let me know where are we now for this post
please note that I got IMEI approve before I ordered SIM CARD
Thanks
02-09-2015 09:48 AM
thanks for the information!
however, when I checked the phone on public website, it shows ok to go. that is why I ordered the SIM card later and try to use it whith the phone. I do not want to purchase other phone.
If the phone does not work with public mobile anyway, please give me refund and cancell the number
I also e-mail to helpdesk this morning
thanks again
02-07-2015 05:01 PM
Hi. Same Info I read as well. Apologies.
Try looking at Walmart, Future Shop/Best Buy Prepaid Section, Telus/Koodo Boxed Phones. Guaranteed w/o need to Unlock. Selection may Vary
02-07-2015 04:11 PM
02-07-2015 10:41 AM
Hi. I attempted to find Further info on that Specific Model. Still Searching. Please remain calm
02-07-2015 10:37 AM
Any solution please...
02-05-2015 08:33 PM
it was a non-contract phone when I buy it through manufactary store directly. before I try SIM CARD of public mobile, I used this phone with rogers pay as you go service plan
please below more informaton of that phone
Y511-T00
S/N: W6X9XB2442300631
CMIIT: 2013CP6835
Thanks
02-05-2015 02:40 PM
What is the Specific Model of your Huawei Y5 phone thing?
02-05-2015 02:39 PM
I checked the specs of your handset. I need to know, which Carrier your Handset came from originally? Rogers, Bell, Mobilicity, Wind?
02-05-2015 02:34 PM
althourgh I got messege said, the phone should work with public mobie network after phone check.
Actually, it does not work
please advise...
thanks
02-05-2015 02:16 PM
please see below messege which I got after phone check
Your IMEI - 865026023203747
Ascend Y511
Your device should work on our Network
02-05-2015 10:22 AM
Hi. What Model is your Handset? Which Carrier your phone came from?
If your Handset supports Only GSM/2G, Handset is NOT Compatible. Handsets need to Support the 3G as Bare Minimum for Compatibility.
HSPA/HSPA+4G/LTE
02-05-2015 10:04 AM
I got same problem, when I check the phone on website before order the same card, the IMEI number got passed. However, after I actived the Public mobile SIM CARD this morning, the card does not work with the phone.
the SIM number is: 8912230000285760435
is there any solution there? or I could get refund as the phone can not work
Thanks
02-04-2015 10:40 AM
Hi. What Sim Card is it? Is it a Public mobile Sim Card?
