text service is not working
pmuser2017
Hi PM rep / Moderator,
I',m on $120/3 month plan with autopay & already paid yesterday from nect 3 months.
Suddendly I can not send or recieve text.
If I receive sms from some one, It says: You have been sent a text but you nedd to have texting in your plan to receive it.......
Same thing for sending too..   it says:Sorry, your plan does not include text messaging.
Pl. help...
Smcanada99
Yes you should msd a mod but in the mean while have you tried power cycling the phone and let sit there off for a bit and then turning it back on. Or try the sim in another device if you have a access to one to just double check in case. Those are the only things that I can think or than assistance from a Mod @Shazia_K
It's probably a system glitch send a private message to mod
** I am not a Mod, please do not include any private info in a private message to me.**
pmuser2017
Thanks Smcanada99,
but voice is working & account status is active
Smcanada99
When you added the funds to the account did you apply the funds to pay for the service. Because its a two step process. One you add funds and two you have to apply funds you added to your account towards your service.
