text message
Allen_2020
I'm going to get a new 25 plan. Is canada-wide text message working?
pmmobile
@Allen_2020  Keep in mind, to send a MMS (picture) you will need to have data on even though it will not charge you for data usage. You can keep data off and when you receive a MMS you can turn it on and click 'download' picture (free) as needed to save data
@kselmak wrote:
If you are anywhere in Canada with access to telus signal you can sms/mms anywhere in the world including canada
If you travel to US, you can get a 10 Day US Roaming talk/text/data options for use while in America.
If you travel outside Canada or US, your Public Mobile features won't work at all. Some travellers use local sims and cheap local plans. Others use free voip apps like TextNow that rely on wifi which is everywhere nowadays.
Welcome to PM
kselmak
RobertQc
@Allen_2020Yes, its the same plan that I use. Not only is it canada-wide text, but its international.
  • Unlimited International Text and Picture Messaging
kselmak
Yes it is
