temporary phone number not changes
luv2cook
My phone has been ported to my old phone number but the phone thinks its number is the temporary number. I cant access my accounts as codes are sent to my old number which I cant access. What do I do?
14 REPLIES 14
@luv2cook wrote:
The code is sent to my email but then it sends another to number ported which I cant see
@luv2cook
so, the code sent to your email and you can login My Account?
if that is the case, you can then go to Profile Page, click Manage EverSafe ID and change the phone number back to the one you can receive
or you can choose to leave the number black for now, so, it is default to send to your email
https://myaccount.publicmobile.ca/en/account/my-profilehttps://myaccount.publicmobile.ca/en/account/my-profile
JRod
@luv2cook
Might be worth following up and do know that you will need to restart your phone once the port is confirmed to be completed
luv2cook
I was told everything would be done by 4:45pm today
luv2cook
@luv2cook
your phone service working?
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
  1. Reset your password to self service account. Once reset, sign in again with new password. Might be able to receive 2FA via email instead to gain access.
    (!!!You will need to click Resend Code and then Send email to trigger the 2FA to email)
  2. Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
If none of those workarounds helps,  please open ticket with support by direct message here:
luv2cook
"didn't get the code?" doesn't show up. I only see "resend code" which is not at all useful as it doesn't go to my phone
luv2cook
Done. Galaxy A11
JRod
@luv2cook
Have you tried resetting your network settings and then rebooting your device?
What kind of phone do you have?
luv2cook
Just to be clear - the phone number for my account has been ported and is set up with my account. But the SIM card is telling my phone that its phone number is a different one and one that doesn't work. Probably because it is not associated with my account or inactive.
JRod
@luv2cook
I am sorry to hear you are still having issues. The other day when I sent you the number to the porting department you told me that you were informed that the port was going to take a few business days.
It’s sounding like that process is still ongoing and is most likely the source of your issues. Give it some more time and follow up if nothing changes after the 3 business day timeline you were told.
luv2cook
Resend is the only option. Going in circles. I think the SIM card is not working properly
luv2cook
"confirm your identity" doesn't give me an option. It only goes to the number I am wanting to be set up and not the temporary one that is in my phone
JRod
@luv2cook
Hello!
Do all texts to the number you ported fail to deliver or is it only the two factor code texts? If you are trying to login to your PM account you can have the code sent via email.
Two-factor code texts can take a few days to properly deliver after a number is ported from one carrier to another. Two factor codes from Banks can take even longer as they will add a delay in order to prevent SIM fraud.
Meow
Choose different mode of delivery to receive in email.
Click on: ‘Didn’t get a code’ and you will get more options.
