07-10-2024 01:53 PM
07-10-2024 02:29 PM
Did your subscription change or did your price increase? Of its just a increase in price it's probably due to the end of the Loyalty program. You nolonger get a discount on your bill
07-10-2024 01:56 PM
@VTANG Did you happen to reply YES to a text offer by mistake ? PM won’t just change your plan for no reason . If something is not right contact support to investigate for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
