subscription not activated
jasintha2019
i was with telus prepaid and transfer to public mobile when finish activation i got this message
SUBCRIPTION NOT ACTIVATED ; some one can help me to solve this problem
@jasintha2019
try this,
  1. Click Logout on top left of the screen
  2. Wait 5 mins for the system to configure on the back end.
  3. Then log in again using the Email  and Password.
  4. The app will then  sends a code to the Email again,.  Enter the code
  5. and you will see the prompt  'Confirm for Full Access' and your Activation will be completed after
if that does not work, open ticket with PM support:
@jasintha2019  Please submit ticket with support
to help straighten out for you
send  a  private message   To CS_Agents
Cheetah24
@jasintha2019We are users like you so we don't have access to your account or internal tools. And hence you need to contact the customer service agent in this case. Please click on https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 to send them a direct message indicating your issue.
