subscription failed
dan1234
Trying to setup a new account, and set up fails at final stage. This is on an android device. How do i get this resolved? Thanks
2 REPLIES 2
dan1234
Hello, we tried esim, but subscription setup failed before the port step happened
Dunkman
@dan1234
Are you setting up a physical SiM card or eSIM?  The setup might have processed anyways.  If physical SIM card, try to insert in your phone.  If eSIM, check your eSIM manager to see whether you see PM eSIM.
If not, then you will need to submit a ticket for customer service agent help via the chatbot.
Click on the chat icon on right lower corner of website or use the following link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
