sms code sent to LAN line
DougCram
trying to transfer LAN line to Cell. SMS code for verification sent to Lan Line which does not support SMS. What do I do?
You could put it in anytime but it might take several days for incoming calls to work.
DougCram
when do I insert the new SIM card
@DougCram
are you still waiting for the landline to port into PM? It could take as many as 7 days for the landline to transfer into PM
On the screen it is expecting you to enter the code, click Didn't get the code? or  Resend code and then choose Send email
You can keep using email to get the 2FA code until the porting is completed
@DougCram  Porting a land line into PM can take a few days and there’s no confirmation text to reply YES to just have to wait for it to happen testing the phone everyday for when it has finally transferred
DougCram
problem solved
