09-05-2023 02:47 PM
09-05-2023 03:07 PM
Yes okay, I will try that.
09-05-2023 03:05 PM - edited 09-05-2023 03:17 PM
@isaac1432786 But all in coming calls go to voicemail ? This makes me believe the port isn’t complete . If you put old providers SIM card in phone does it still work ? If so you need to call that number to re start the port request
09-05-2023 03:02 PM
I did just port the number but I received the confirmation and when I call out it is showing the correct number.
09-05-2023 02:53 PM
@isaac1432786 Did you just port a number into PM or miss the confirmation text ? If so there’s number for live support to re trigger the port request will send you it private message to get it fixed
