sim card
tomdellandrea
have not received yet 3 we
JL9
Unfortunately it seems the sim delivery times are getting longer and longer over 3 weeks in many cases according to customers, going forward you may want to check out some the alternatives that are less hassle.
@tomdellandrea
It should be arriving this week. If not by the end of this week. Please contact a CS_Agent on the status.
If you ordered it from PM it might take up to 4 weeks to receive.
You can contact agent but I doubt they will tell you more except 'we received and are processing your order'.
Hi @tomdellandrea   we are just customers here .  But if you ordered sim for 3 weeks, you should get it this week.  PM usually ships the sim around 2 or 3 weeks
but if you like, message CS Agent and ask for update here:
tomdellandrea
order number 290533 have not received yet
