02-05-2020 11:57 AM - edited 01-05-2022 09:21 AM
02-05-2020 04:28 PM - edited 02-05-2020 04:29 PM
@geopublic wrote:
@KimS57 wrote:Emergency calls only. What does this mean?
@KimS57 It means your card hasn't been activated or your account is suspended.
@KimS57It could also mean that your phone isn't compatible, that there is a temporary network problem, that there is no Public Mobile signal in that location, or that the phone is connected to a different company's network. The only thing that message really means for sure is that you can only make calls to a select few phone numbers, the main one being 9-11.
02-05-2020 03:13 PM
@KimS57 wrote:I opened an account already.
So you did all this stuff?: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Start-Guide-Setup-Activation-Port-Dat...
02-05-2020 03:08 PM
02-05-2020 01:37 PM
@KimS57 wrote:Ordered the Public Mobile sim card online and my daughter changed it on my phone. This was last night. It is telling me Emergency calls only.
A SIM on its own is meaningless until it is activated with an account. The mere act of purchasing a SIM does not activate it. Did you go through the activation process?
02-05-2020 01:12 PM
02-05-2020 12:37 PM
I've tried with removing sim. Everything else is good. I'll wait till help arrives. Thank you.
02-05-2020 12:35 PM
@KimS57 wrote:Just a newbie here. Can't be susended yet. I'll get it figured out eventually I hope. Thanks.
Oh good you're still around. We didn't have a lot to go on with your first post. We might be able to help you shed some light on what's happening with some more details. Please do tell your story and chronology of what you've done. No personal info.
02-05-2020 12:34 PM
Thank you I will. I'll wait till help arrives.
02-05-2020 12:31 PM
02-05-2020 12:12 PM
Hello!
It might mean that you do not have service to enable any functions with the exception of dialing 911. Emergency calls only appears when you are not experiencing proper signal.
02-05-2020 12:05 PM
02-05-2020 12:03 PM
02-05-2020 12:01 PM
it means you can only call 911
- try logging into your account and see the account status
- if active then a sim or phone issue,
- if inactive possible payment failure.
- if can;t login or email not recognised then there are account issues
- try doing a manual network search
- try sim in another phone
