3 hours ago
I can't sign in because my phone isn't working can i use another number or email?
3 hours ago
HI @fehrkid
if just a phone problem, you can put the sim card in another working phone and get the code that way
or you can also get the code via email, click Didn't receive code and then Send email
or you can also click Didn't Receive cade and end via voicemail. Then you can use another phone to call your voicemail and get that code that way
3 hours ago
@fehrkid if you can't use the PM app you should be able to sign in to the website. If it asks to enter the verification code select the link that says "Didn't get code", you can then choose to send by email
