05-23-2023 02:41 PM
After a significant amount of frustration, I was finally able to sign in to my account with the user name and password. I confirmed the correct email address was in the profile and attempted to log in to the "My Account" to change the billing information. When I tried to log in to the account with the confirmed email address and password, it keeps telling me that either one or both is incorrect. Repeated and ongoing issues trying to sign in to the "My Account" portion of the page and when I sign in with the user name and password, I cannot find any links to change the billing info. I feel like I'm going in circles.....
05-23-2023 03:11 PM - edited 05-23-2023 03:21 PM
@pmbc wrote:@Katie3 For best success, you should be logging in from a desktop/laptop browser. If having the trouble you have been experiencing, try your browser in incognito/private browsing mode. Usually that's the fix if you know the email and password. There have been reports of some flakiness when using mobile browsers. Are you having trouble when using a mobile browser or are you using a desktop/laptop?
@Katie3 , to add to what @pmbc said, due to webpage has cashing issues I always sign into “My Account” with my iPad using a browser in private / incognito mode with no issues except on nights when Public Mobile is doing maintenance until late morning! Otherwise no issues!
Also, I never save my sign in information on my browsers.
Edit: Due to my typos!
05-23-2023 02:50 PM
another possibility I have run into before with saved credentials is sometimes they insert a space either before or after the string of letters/numbers.
The space can sometimes confuse the system into believing it was an intentional space (i.e. part of the username or password), and may not work with logins on various sites.
05-23-2023 02:46 PM - edited 05-24-2023 11:29 AM
Any chance you have a Telus My Account as well, if so, that could confuse the browser and caused the issue
Either way, try to login again using Incognito mode and see if it helps
And do you use any browser extension like dark reader (or other dark theme extension ) or pop up blocker? If possible, disable them and try again.
If using it on Windows, you do so by running this for chrome :
"C:\Program Files\Google\Chrome\Application\chrome.exe" --disable-extensions
or
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --disable-extensions
Finally, you can also try to use a different borwser with Incognito mode on a desktop/laptop or on a different device
And if nothing work, please open ticket with PM support:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: Chatbot
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
05-23-2023 02:45 PM
