01-12-2024
04:45 PM
01-12-2024
04:50 PM
computergeek541
My wife can not access her account as we have the same email address, how do we set up a separate account for her
01-12-2024 04:54 PM
Each PM account has to be opened with Unique email address.
Aliases are allowed meaning abcdef@gmail.com is NOT the same (for PM) as abc.def@gmail.com even though it is the same email account. Thus use alias if your mailing system allows it.
01-12-2024 04:50 PM
@clinkerboy wrote:My wife can not access her account as we have the same email address, how do we set up a separate account for her
The activation system should not have allowed that. To get this fixed, you'll need the help of a customer support agent. Please open a ticket using the chatbot.
If the ticketing system using the chatbot gives an error message, send a private message to CS_Agent.
01-12-2024 04:49 PM - edited 01-12-2024 04:50 PM
@clinkerboy yes PM system is one e-mail for only one account.
Some people might suggest using email alias, but it can cause other issues depends on the way you setup the alias, especially after system update
3hy not get a FREE email address, from Gmail or Outlook.com , for the purpose of the new PM account??
