08-11-2023 03:01 PM
Hello, I just transfered my number (or so I believe...) and activated by eSIM. When I try to make a call I get " the last line is no longer available" message. I got the text from Virgin to transfer the number and I believe it went well. I have an Iphone. Not sure what is going on, or what this means?
Phones
08-12-2023 01:08 AM
Does your Virgin SIM Card still work and have reception when you put it back into your phone?
08-11-2023 03:03 PM
thank you so much!!!
08-11-2023 03:03 PM
@jvj There’s a number for live support to give status update on port or re trigger it if needed . Will send you private message to get it fixed
