12-28-2018 01:30 PM - edited 01-05-2022 02:54 AM
just purchased a sim at walmart.. said i'd set up the sim at home..
initially went to the second screen, selected the option to keep my current number.
after entering the info, would not progress to the next page.
now, when i try again from the start, not progressing past the first page...
need help ASAP!
12-28-2018 03:18 PM
unfortunately, after having waited over an hour and using a different browser, it still gives me an error after the second page.
guess i will be contacting a moderator directly.
this has been quite frustrating to say the least.
12-28-2018 02:28 PM
yup. it gave me that error where it told me the sim was in an open session and i'd have to wait 50 minutes before restarting the process.
thanks for pointing that out.
12-28-2018 01:53 PM - edited 12-28-2018 01:57 PM
@Jackhyf63 wrote:I suggest you send a private message to the moderator team and ask them to investigate. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
@Jackhyf63The process for verifcation when contacting a moderator has changed.
Please see the announcment here then read this.
12-28-2018 01:50 PM
12-28-2018 01:50 PM
@marcnav, you might also need to wait an hour or two for things to flush out of the system otherwise you might get messages about the SIM card being an issue.
12-28-2018 01:39 PM
Thanks. Will do and report back.
12-28-2018 01:35 PM - edited 12-28-2018 01:38 PM
@marcnav wrote:just purchased a sim at walmart.. said i'd set up the sim at home..
need help ASAP!
@marcnavClear your cache/browsing history and try another browser / disable add-ons / private browsing / incognito. If you are using safari / cell phone go to a real computer.
