Monday
i changed from bell to esim public mobile and since then i havent used it for outgoing text and calls, it says SOS only. but i am able to use the data. my bf has same plan but he has no problem at all.
i tried to set my public mobile as primary and turned off bell, as a result it showed no sim. idk what else to do and customer service don’t seem to help either
yesterday
i tried to do it but still shows no sim. the agent only says there’s no problem on their end and looks like not interested to look for any other solutions to help
yesterday
hi. yes bell was still active and I did reply Yes to their text for number transfer. should I tell the support agent to reset account setup?
Monday
the Public Mobile esim is there? With Bell sim turned off, try Reset Network settings
if you still see SOS, you need PM to help.
You won't be able to open proper Chatbot ticket, so just message them
Monday
hi @Glycy
have you reply Yes to Bell's text about the port?
and Bell sim has been working until you turn it off? then the port was not done
but the fact that PM sim shows SOS, look like there is a problem with the account setup. Please message support agent for help
