10-03-2023 08:34 PM
Yesterday I switched my phone from Fido to Public Mobile with no issues. At 12:21 today I switched my wife's phone from Fido to Public Mobile and followed all the prompts, replied YES to Fido's SMS about transferring the number and here we are 5 hours later and my wife's phone is not working. I have gone through every troubleshooting rgimen provided on this god-forsaken chat line including network reset, removing and reinstalling the old SMS card but nothing works. Anyone have any ideas?
10-11-2023 09:32 AM
Both phones are working now. Thanks
10-11-2023 09:31 AM
Your response was helpful
10-05-2023 12:59 PM
I apologize for not responding to the suggestions from the community but the following should explain why. After three horrendous days I finally got both phones working properly with the assistance of several PM customer service agents. Both phones were operational at around 9:00 am PST today, October 5th.
10-03-2023 08:44 PM
HI @deejay69
first, confirm if your sim was provisioned properly. Make sure your wife sim can connect to PM network. If not, try testing it on your phone, try Reset All Networks or Reset Network Settings
If it connects, confirm it can make outgoing call. If it can, and just unable to receive incoming calls, then it is a porting issue. There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
if it cannot connect at all, cannot make outgoing calls, then it is a sim card provisioning issue. In this case you need to engage support here:
10-03-2023 08:41 PM
Is your phone working and still having your proper number?
You didn't say and it seems obvious but you have the new sim in your wifes phone right?
10-03-2023 08:36 PM
HI @deejay69
first reboot the phone then check if her phone can connect and makes outbound calls? just not receiving inbound?
I will message you a number to call porting team and they can confirm the porting status. Check your Community inbox
